help two cyinders running lean on 98 srx
supersrx
Lake Orion MI.
i have 98 srx 600 and the the center and clutch side cyinders or running lean and i cant figure it out i cleaned the carbs and replaced the fuel and oil lines and i checked for vacuume leaks and there was none.
DId you clean the carbs GOOD, blow through each passage with carb
cleaner then shop air?? jets too??
:whine: I cleaned the carbs with carb cleaner . I think I'll take them apart one more time my I did not get it all
