Concept Carbon
I have been having problems with my speedo, just wanted to know if anyone would be kind anough to let me plug my dash into there viper to see if its ok.
All you would have to do is disconect the harness from the dash under the hood, plug in mine and spin the track.
thanks Jay
thanks Jay
do u want me to go at your place and have a look lolll
Concept Carbon
thats cool thanks for the offer though, I know its ethier the sensor or the dash, so just waiting on a new sensor, but have a feeling my dash is messed sense its more expensive with my luck.
the only way to check the dash is to buy a special tool harness adapter from Yamaha or plug it in to some one elses sled. I had some of the aircraft avioncs guys ( aircraft electrical engineers) at work tear it apart and they couldnt find anything, yamaha makes them so you cant fix em.
well i'm sure you will find a broken wire in the cab
you can try to unplug your dash and check if those wire are good they go direct from the sensor to the dash so its easy
Concept Carbon
all the wires from the sensor to the dash are good checked them and they all have continuity.
then to make sure none were rubbing i removed all the black tape from the harness spent awile inspecting all the wires the re tapped and covered in very good hi temp wire aviation protector
my dad have a plane now good thing i know u if i need stuff from there lolll
Concept Carbon
lol, if he needs any sheet metal or composite work let me know.
sure i will let u know he buy alots of small bolts and rivet god they are very expensive ... dammm aviation stuff are so expensive... he keep it clean so anything that he need to change well garbage and put new one ....if someone tell u about deal for radio communication let me know lolll
Concept Carbon
still looking for a favor.
only have to lift the hood an unhook the harness and plug in mine.
BenderSRX
Speedo
I dont know if you got it fixed or not but my roomate has an extra speedo in the shed and if you want we live in Constance Bay you can come out with your sled and try it or come and get it and try it out and see if it works. Its off a 2002 Viper
I'll be bringing mine home from the cottage this weekend. I live out near Carp. Guess you can try it if you want. Can't see any harm?!?! How hard is it to get at the connector?
SRX7
will it work on an srx?
Concept Carbon
cool ok thanks guys, it wil only work on a viper, its real easy to get to the connector you just lift hood and unhook the conector that goes into the back of the dash, takes 10secs super simple.
I will let you know if i need to do this i bought a new sensor I should get it tommorrow, if that dosnt fix the problem its got to be the dash and i will need to test it out.
thanks alot for the offer guys really apriciated it, I let you know.
thanks Jay
thanks Jay
Concept Carbon
well changed the sensor today and she works, kick ***.
thanks alot for all the help and offers, really apriciate it.
do u go somewhere tomorow for a ride ???
Concept Carbon
i think they call that meo around here ...so i guess your not going for a ride today you look online lollll
SRX7
were heading out tonight from orleans all welcome.
Concept Carbon
sorry drags were today sucks. where are you going from orleans. Im thinking of heading to lac st piere and just running on the lake.
