Brake light always on
SNOWRULES
Ottawa. Ontario, Canada
The brake light on my 98 srx is always on. Has a brand new bulb in it so it's not that. switch at the brake lever seems fine seems to spring back no problem. no pinched wires in the bar pad area that i could find jack under the seat is plugged in tight. any ideas?
remove the brake switch from bars and manually move the tang on it and see if it goes out. If it does when you reinstall it make sure the tang fits in the brake lever.
