advice running RX1 helix on 98 srx
jayman54
peterborough ont
im gonna do my clutches and am planning on ditching my roller rooster on the count that its cracked on several spots and i do mostly lake running and i'm sure that big chunk of aluminum isnt helping me its massive.. i was told that an rx1 or 51/43 helix works well on these and i was wondering who has this setup and does it work well... it currently has a 35/31 helix in it and i find it works alright but lacks on the lake... what color secondary spring and wrap are u running??? green 60-70 maybe... and i'm running 8bu-00 weights with a single weight in the tip.... and the primary has a black spring with a white dot, is this a stock spring?? i just want to get this right and go ride and want to know from someone that has this setup and it works well any help would be gladly appreciated...i wanna go fast!!! lol ~Ricky Bobby
stock primery should be blue-white-blue. dots on black spring.. yes run the 51-43 helix with 70 degrees wrap on green secondery spring.. this should work good for you!
are those the stock weights?? i was told to run those with 4.5 grams in the tip is that what is in there now??
This is the set-up I have in my 98 srx7.
This is from LOTS of people here.
www primary spring,
8dn-20's w/4.5 g in each hole.
Grn secondary spring set at 80 degrees twist,
advant-edge 51/43 helix,
23/40 gears,
1 inch track with 144 1.18 studs.
From the little running I have done, it seems to pull hard.
mul.
i'm only hitting 105 on radar on the lake which doesnt seem right and it seems to lack top end or just takes forever to wind out...i had a stock srx walk all over me the one day... i want my top end fast and not to take forever to get there and who knows how the setup i have even works well i didnt set it up...the sled runs great just it feels like its lacking by clutching
spring is b-w-b. if you are running the 8bu00 weight, your good to go, they work real good! what are your rpms at?
mulderdad's setup is the most common for srx
with WWW primary and 8dn 20-s with 4.5 grams in both holes
greed or red( stock) secondarys at 70-80
51/43 (rx1) helix
Ramb
