97 vmax 600 after doing some work(clean carbs, new head gasket) the temp lite flashes.Two longer flashes followed by a short flash. Coolant level is good and does not over heat. big ride this weekend dont need a break down.
Does it keep flashing it over and over??denkel said:97 vmax 600 after doing some work(clean carbs, new head gasket) the temp lite flashes.Two longer flashes followed by a short flash. Coolant level is good and does not over heat. big ride this weekend dont need a break down.
I'm showing "Discontinuity or shorting of the TPS is detected"
Here's the fix,
and
and
