Brake light issues still
SNOWRULES
Ottawa. Ontario, Canada
My brake light on my 98 srx is always on both fillaments lit. i put a new switch in and still no change. i checked the wires from the back all the way up the side of the chassis till it goes into the big wiring harness no rub throughs. i have continuity from the back socket into the switch as well as from the back socket right up to the blue wire at the main plug at the magneto. if i unplug the switch the light still stays on brake both fillaments lit. this leads me to believe and correct me if i'm wrong that there must be 2 wires touching somewhere up inside the harness before the switch, because this is what the switch does is close the circut to activate the brake light. when i put the new switch on i just activated it by hand and it seemed to work in reverse when activated it would dim the light from brake light to running light it only did this for a few seconds then i couldn't get it to do it again. any ideas guys?
no i havn't unwrapped the harness yet that is my next step pain in the butt though. there are no visible rub throughs on the outside but maybe something wore together inside where i can't see.
