strange power problem to thumb warmer
thesledsurgeon
Eden, New York, 14057
After my thumb froze last weekend I checked to see if there was power the throttle warmer w/ a test light . it flashed on and off constantly what gives? power to the handwaarmers doesn't do this..
Wire connection or broken wire problem most likely. If the lights do not flicker on and off, then power from the main control relay should be ok. It could be the supply to the thumb warmer, or it could be the ground. Test at the connectors under the handlebar pad to see which it is.
