racesx
I have checked power valves, stator, coils, plug caps, all wiring under the motor and Throttle position sensor (TORS is unhooked). My 2001 SRX will load up from 5000 to 7500 RPMs and goes way rich. It will not go over 7500 on the ack stand. It will foul the plugs as well. The carbs are clean and the floats are set.
Could this be a CDI problem only thing I have not changed or checked
