MICHAELSF150
Wondering what my max rpm should be . 600 twin vmax sx 1998.
8000.I always clutched mine to 7800 and climb to 8000 on a long run
Yup 78 to 8
MICHAELSF150
If it hits around 8100 Rpm is it a big deal?
Well your overreven and making no power, but i've seen worse..MICHAELSF150 said:If it hits around 8100 Rpm is it a big deal?
MICHAELSF150
how can i fix it from over reving, it didnt do this last year, the only difference is i put a ultimax 3 belt on it. I already took out the little spacers on the secondary clutch. is there anything else i can do?
Belts can have alot to do with it, different hardness and stickynessMICHAELSF150 said:how can i fix it from over reving, it didnt do this last year, the only difference is i put a ultimax 3 belt on it. I already took out the little spacers on the secondary clutch. is there anything else i can do?
i only use OEM belts and i think alot of others do to.
try a OEM belt or add more weight to your clutch weight tips.
MICHAELSF150
is there anything in the tech center that shows how to put more weight on the tips? I have never done any work on a clutch before.
MICHAELSF150
Could this also be caused by dirty clutches?
Try a search i remember guy's just talking about how they remove rivets,MICHAELSF150 said:is there anything in the tech center that shows how to put more weight on the tips? I have never done any work on a clutch before.
every body does it different..
could be,,if you have any wore out parts,you need to pull her off and goMICHAELSF150 said:Could this also be caused by dirty clutches?
right through it,check it all out.
MICHAELSF150
I dont want to buy a new belt because the one on there is new.
MICHAELSF150
Have you heard of this with a ultimax3 belt?
yamaholic22
Usually the dayco belts drop rpms from the 8DN, but the 8CH is softer than the 8DN, dont know how it compares to the dayco though. But more than likely from your results the dayco is a harder, less sticky compound than the 8CH or 89L that you used to run and now the clutches need more gripping force in order to hold onto it. Give the clutches a good cleaning with hot, soapy water and a scotch brite pad, blow dry with compressed air, check condition and tighteness of all rollers and bushings, and add a little weight to the tips as Daman said. My method of extraction for the stock rivets usually involves a center punch and drill press. Works well.
