80 srx
welderwelder84
canada
im having a hell of a time getting it to sart. lots of spark and gas whuts up!! it ran good in the mornin one pull shut it off. now its got no go.
stuck inlet needle? Stuck float? stuck choke? Water in the gas..which can really frig the inlet needle up. My 340 Exciter uses 1 of those types of carbs and it is acting up now, flooding really bad.
Compression
It is possible thatnyou got the last run from it. When 2 strokes wear enough they just wont start again because compression is JUST low enough. Do a check. Also just because the plugs fire externally once you install them for some reason they just wont fire.
Flooded out.........Take a compression test........Call wiesco and get a set of new pistons and rings. Just my 2cents. Oh check the chrome bore for pelling. I have some spares if needed. Dean-o
