gears, clutching for 98 srx in 660' drag, need help quick
98700
Wishing for snow!
Hamilton, Ont
i want to go racing next weekend, what gears and clutching should i do for the 98 srx 700. we will be running the 660' snow drags. the sled is all stock exept the heads are done and there might be some porting. it is clutched but i unno what. i want to do good in the 660'so lets see what you guys think.
21-39 or 22-40 is olso very good for racing! clutching, b-w-b 8bu 00 weights, 48-42 helix and green maybe silver secondery spring, green at 70-80 degrees twist, if you start on tracks nailed to the ground?
and do adjustemts to the suspention, very important! get it low put "washers" on bottom of the transfer rod to pull it down, tighten the straps in front of susp, and set rear shock in soft, let front shocks run soft as it will lover the sled, or strap it if legal..
yes you can strap down the front shocks with any kind of strap that will hold it, so you get i lower, lower is usually faster!
