Wally
Anyone know where to pick up a constant 12vdc feed for a heated shield, on
the '00 sxr 600 ?
the '00 sxr 600 ?
SWEDE
Take the handlebar pad off, and find the blue wire I believe or blue striped wire, this is hot and you can verify it with a test light.Tap into that and ground it to one of the bar mount bolts, you should be good to go.
