Question about Limiter Straps
Cuzino19
Fort. Ontario
Limiter straps, Please Read, NEED HELP ASAP.
Ok, so one of the limiter straps on my M10 broke, and I am suppose to go on the TY Manitoba ride on tuesday, the straps i ordered have not yet come in. What I was wondering was, can you use other limiter straps from other suspensions, like somehow modify it to work with the M10? I need to know what I can do, to get it ready for the ride, if it does not come in tomorrow. Help is appreciated, Thanks. Mike.
Its not that big of a deal, just find one thats fairly close length wise and it will be ok.If you can compare it to your m-10 one you could even drill the necessary holes with a stud hole drill.
Tried to give you the same advice over on HCS, but couldn't log in. To get you by, you could just drill it with a regular bit. If you find one too wide, just cut it down in the spring area where it's tight.
As Swede said, it's no big deal
