94vmax500 will idle, but die when gas'd
magyver
madison WI
94vmax500 will idle, but bog/quit when ya give it some throttle
well i havent ridden it since 01 and it sat in our shed on concrete till recently. w/ that said, i cleaned it all up drained all the gas, cleaned the spark plugs, took apart the intake plastic and cleaned it all up and put in fresh gas. w/ that said, the after the famous 30 long hard pulls she fired right up. she would idle perfect. i let it sit to burn up the gas that i couldnt drail (couple oz max) and came back and it would die when gas'd. but if i put the choke on half way, it will wind up. somthing simple?
also, the throttle was getting caught at like 1/6 the way, but if you let off and gave it hard, it would go normal. so i took off the cover of the left intake and sprayed some wd-40 in there as thats where i thought it was sticking. it helped alot and she stopped sticking for the most part but still i can feel where it was doing it b4. but thats the least of my worries. i need it to go when i gas it.
anyone have any info? i moved from a farm to the city hense the lack of use and im gonna put her up for sale to help pay some bills.
thx in advance
You need to clean carbs well,pilots sound puged some..
pull all jets spray carb cleaner through(jets and passage ways) then
blow with shop air ,check everything out and resemble,,should be good to go
Also sounds like the slider is hanging up on something. Make sure the slides are good and clean as well as the bores. Figure on 20 minutes minimum per carb. Take your time and go liberal on the carb cleaner.
