94 vmax 600 dlx clutching problems
cleansocks
St. Thomas Line, Newfoundland
Hi,
My buddy's sled has the following problem:
"Basically, going through a tight trail at low speeds, she over revs, then as you open it up on the pond, the rpm stays while you accelerate. She was revving at 5500+rpm at 35mph but then stays there at 60+mph, where she should be. Any thoughts??"
Any suggestions as to what this could be?
Thanks!
cleansocks said:
engages @ around 2800-3200rpm maybe, wide open 6500-7000 maybe.
Thats alot of maybes..:)
you want 78-8000 on top no more....
you need to see what's inside that clutch for parts and post back,
make sure nothings wore out, might need to lighten up the tip
some.
check secondary wrap too see were it's at.
Thanks for the help.
I figure somethings broke/wore because it just started acting like this apparantly.
Any ideas what kinda part failure would contribute to this? I guess it could be any number of things?
