Wrecked 99 SX600R
sledneckdon
Upstate, NY
I am looking for long travel front shocks and radious rods for my wifes wrecked 99 SX600R I have posted in the classifieds and in the SX section with no luck. Maybe someone on here might have the parts I need. The rear is already long travled.
i have a set of radius rods from a 2001 sxr500 (same chassis) that where taken off when i put cbperformance aluminum front end kit on the sled. cannot offer you a trailing arm because that is the sam one that was wrecked on my sled. as for the shock, get it rebuilt and the shaft replaced at pioneer perf or at a local guy if you have one. it was almost as cheap for me to put cb's kit on as it was to replace the entire front end with new oem so i would seriously consider it if i was you.
I have Viper shocks and SXr shocks that will bolt in, but you do have to change radius rods.
I thought you could adjust the radious rods out to compensate for the longer front shocks?????????Doesn't the inner attach point on the radious rods have an adjustable rod end/lollypop style rod end???
i have viper radius rods and a viper sway bar for $125 shipped and in a week or so i will have a pair of viper front shocks for $125 shipped this should be all you need except the trailing arm right?
