87 Enticer help needed!
Styles211
Woodstock,Ontario,Canada
I just salvaged this sled from a friends backyard, it has been sitting for 2 yrs to his knowledge. It has good compression and spark. The problem I am having is locating a carb for it. He took it off and miss placed it. I have called around and no one in my area has one. I was wondering if I could put a different carb on it rather than the stock one?
Styles
it had a mikuni buterfly on it stock. i have one from an older 340 if you need it.
after you get it running make shure to check the crank seals as she is old enough for them to have dried out.
