need some center shock specs
jayman54
peterborough ont
i had a bad center shock in my 98 srx and i ended up getting another from a recker (wanted to go riding)and noticed the spring was different and my limiter straps are still loose now with that shock installed and theres lots of tension on the shock... so i was wondering if some one had put a viper shock in... this sled had some mods done when i baught it and and i need the measurements cause a local shop has my other shock trying to fix it...it broke the refill valve off and had 0 pressure cause some idiot put it in upside down... so i was wondering the shock dementions between the 2 or whats the length on the viper shock extended and the srx shock from either center to center or end to end...any help would be greatly appreciated cause it the other one is longer i will steal the valve outta the new one and put it in the longer one....
shocks
The srx center shock should be 12" (305mm)
I don´t now about the viper but it should be close to a sxr shock who is 12,85-12,9" (326-328mm)
