I did some searching, and came up with the torque for the primary. 87ftlbs, loosen, retorque to 43ftlbs. but i came up empty on the others. need the secondary bolt, helix, and roller bolts. thanks
Shawn
Shawn
yamaholic22
These are not specs, these are what i always go and have never had a problem: I usually go about 30ft-lbs on the secondary bolt. Helix i have definately never checked, but i would say around 17 ft-lbs.
thanks I really only needed the secondary, but I couldn't find this info here. So I figured if I started a thread, maybe it would help out others later on.
thanks a bunch
Shawn
thanks a bunch
Shawn
is this on your 700 xt??
yes it is on my 98 xt700. thanks daman
Shawn
Shawn
46ft.lbs if ya want to be technical.... LOL
This is what I do
75 ft lbs then relax (loosten) the bolt and retorque to 45 ft lbs. That's when I have a torque wrench handy. When I don't then it's wellllllllll yeah, about that tight.
Madmatt
Madmatt
reading back on this thread he's got me confused weather he needed
primary or secondary...TQ's
FuzzButt
Torque spec right out of the manual on page 9-15.
Primary First 85ft-lb then 43 ft-lb
Primary cap 10 ft-lb
Spider and Sliding Sheave 145 ft-lb
Roller and weight bolt 4.3 ft-lb screw 2.2 ft-lb
Secondary 46 ft-lb
Helix (page 4-10 "A") 17 ft-lb
Secondary 46 ft-lb
He's got 'em all now..lol
thanks guys! I knew someone would come through! You guys are great!
Shawn
Shawn
yz125mm700
are the specs the same for a 2000 mm700?
