YAMAHOWIE
Is 120 across the board OK for a 01 SRX ???? Thanks !
marty f
YES THAT IS PERFECTYAMAHOWIE said:Is 120 across the board OK for a 01 SRX ???? Thanks !
yamaholic22
It depends highly on the compression tester being used. It is more imporatant that the numbers you get for each cylinder are VERY similar, no more than a few pounds difference. Leak down tells you a lot more about an engine.
^ i agree..
i got, p140 ,c135, m135 on my '01, if that gauge is right i'd say
your down a little, but like holic said a leak dowm will tell the truth..
YAMAHOWIE
Thanks fellas ... I appreciate all the replies. It seems a little flat on top end and I'm trying to figure it out.
Maddogs700srx
My 00 with 10,000 Miles had 132 132 130 when I refreshed it. I have only put 100 miles on since then. I check it out tomorrow and see what it improoved.
davessrx
A cheap gauge will always be off. I tested my sled (01 srx) 1st gauge said 135-136 and 2nd gauge said 120 on all 3. As long as they are within 5-10 percent of one another and not toooooooo low you should be ok. Flat up top.....powervalve issue??? I had a bad wire cap and fouled #1 plug and it wouldn't go over 80!!!!!
I'm hoping my $120 MAC is right......
yamaholic22
daman said:I'm hoping my $120 MAC is right......
lol, if accuracy comes with the dollar that thing should read a REAL tight spread!
@holic,
Maddogs700srx
I had a cheap 30 dollar analog one I picked up. It read 130's across. I picked up a sweet digital one for 180.00 and got the 132 132 130 readings.
Thats not bad...
YAMAHOWIE
My tester is a Milton.. I think I paid 60-70 dollars for it. Seems like a decent one, but by your guys standards maybe it's a cheepie...
Sled has 4k miles on her.... maybe it's time for rings..??
seca
my 99 srx 700 has 120-120-120 with 7800km on it. i have a cheap tester that i paid $39.99 . i would also think you are fine as long as all your readings are within 10% of each other.
Some would say yes,,it's cheap and easy to do,really don't need toYAMAHOWIE said:Sled has 4k miles on her.... maybe it's time for rings..?
hone eather..
like said earlier do a leak down...
98700
Wishing for snow!
well i got 100 across on a cold engine then 120 across on the cold engine. runs like a champ, but should i do rings this summer? i want to just so i know i have good compression. my 98 srx has over 8800 on it now. riding this morning at 10:00.
Yes go ahead,and mic your pistons out too to see if there still within98700 said:should i do rings this summer? i want to just so i know i have good compression. my 98 srx has over 8800 on it now. riding this morning at 10:00.
specs...
