transfer kit?
..SNAKEBIT..
NE IOWA
is it possiable to just take off the adjusting nuts, so it does not couple?
dont know if I want to go and make a kit and then decide I dont like it?
Installing a 144x16x2" track with 8tooth drivers, and CB drop brackets
Marty, you may mess up the threads by doing that. If you are doing it for your mountain trip just take the rods off and add straps. there is a set on ebay right now under yamaha rx-1. Paul
how do you guys have your suspension setup without the rods?
Pat
Marty
jackthe center spring half way, set the straps in the stock posistion, and hold on. Maxdlx
