reddog mmax 700
i have pi end dumps on my mmax 700 it says on the spec sheet to run the sled at 8150. but the thing is i'm turning up 8600. i use heel clickers i got the frist hole loaded right up i can't put any more washers on the weight or it will hit the clutch,i just finished porting the motor,carbon tech reeds,i run a hymark roller clutch with a stright 45 helex set at 70 and a 22/39 with 8t drivers. i guess i want to know if it is ok to over rev a bit or should i try somthing else...reddog
The end dumps run at 8400 rpm but still do ok at 8600. It,s the centre dumps that need low rpm,s.
reddog mmax 700
porting
turk...should the pipes run a bit higher with the porting...i used race logic templates to do the porting
call race logic & ask what rpm,s their porting should run at with 8400 rpm pipes. I have never used their stuff & have no clue how it works.The porting has to match the pipes or your gonna go slower.
change_up
I ran them at 8500 after it built top speed on my 600. The accelerating rpms were right about 8200 until I got up there in speed. They are a higher reving pipe than the centre dumps like Turk says. I'm no engine guy myself like some on here but I wouldn't think that the porting would change rpms too much. BUT it would be a good idea to call race logic and find out as you would get the best performance.
