got smoked by a Merc Twister 440 (again) today. I realize he's got twin carb but what options do I have to put on this sled (and stay single carb for stock class) that may help me keep up? It's got the stock Keihnin 44-38 in it. I've jetted it about as good as I can get it and can't catch them twin carb sleds. it's a little boggy off the line too, engaging at 4000 right now with a Comet 108 . maybe just need to lose a few pounds eh? I'm oval racing this sled.
any help would be appreciated. rules are any carb(s) for stock, no flatsides though
thanks in advance
thanks in advance
Chris
I used duel 38 roundsides , runs real good Used Phazer carb boots and boost bottle , Real quick , i still have to to some pilet Jetting it has a slight bog at lower end but when it kicks into the mid range its insane
thunderjet440
- Oct 30, 2005
what sanctioning body are you running in? BEVRA? i thought all stock class sleds had to use the same size carb as stock? i'd probably try a 38 mik
A guy used to race in Eagle River on a 76 or 77 exciter and no one could touch him.I think his name is Brian Ehman.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
We just won the 440 fan class in our oval racing circuit on our 77. We are running a single 44 mm carb. We also are running a 108 clutch on there and the sled was untouchable this last weekend.
haven't run a BEVRA this year just a couple at Albright Shores this year and Crystal Lake. (kids stuff you know?) their rules say any carb(s) and you can change the sled out to twin carbs I found and still run stock. (which makes it kinda improved stock if you ask me) but anyway just looking to get a little more out of it. In the 108 I've got a blue spring and A-18 arms. It's a little boggy out of the hole still at 4000 engagement. may have to get a little higher yet (probably my 235# doesn't help much).I've finally got it turning sweet in the corners just need to get a little better acceleration out of the corner now.
Thanks for the help.
GP292Racer
A good mikuni roundslide setup will help a lot. Prob twin 38's would do it. You'll find throttle response much different with any slide carb. You can actually run a smaller slide carb than your original butterfly carb due to the increased airflow.
