Oil Warning Light on a full tank of oil...
Blue700Triple
2000 SRX
Has anyone had an issue with their oil warning light coming on even though the oil resevoir has plenty of oil? The light came on the other day and stayed on even though the tank was 2/3rds full at the time. Since that time, the light has flickered off and on a few times but for the most part has stayed lit.
I disconnected the sensor coming from the oil tank but the red dash light stays lit. Could it be a short in the wiring harness somewhere or is the sensor more that likely bad???
Two things, first i think the 2000 had a an oil sensor recall/bulletin second the harness under the engine was bad for rubbing and shorting out. I had both done on my 2000 SRX............James
Mine did the same thing and i thought it was just the sensor. But after my sled died on the trail i found it was the wiring harness under the motor being rubbed through. Fixed that and now all my lights work correctly.
