Viper Setup!
Viper-Rules!
Kitchener,ON Canada
I set my sled up according to the instructions I found on here. I have close to a 50/50 gap on transfer rods with the fra adjustor set in soft position. I have the limiter straps set about half way and the centre shock I have it set fairly loose. The sled seems to ride fine, but I'm still struggling with a lack of ski pressure. Transfer rods are set to stock settings. How hard should the ski's be to turn, when sitting on a flat cement surface. I can turn it without much resistance. The sled glides fine through the powder, so I'm sure I don't have to touch transfer rods. The front shocks are set to std setting around 5". I just need to find a way to get more ski pressure, so the sled won't dart as much. Should I tighten the limiters more or increase the front ski preload?
