Sno_Racer_Xtreme
might be doing a little bit of lake racing sometime soon and i was wondering if anybody had a way that they strap the front ends down on a srx.
thanks
thanks
I just loosen up the spring tension and it will drop right down to where ever you want it, then using a old peice of nylon motorcycle tie down strap, cut it to the right length, melt a hole in each end of it. This is from eye bolt to eye bolt on the shock, install the strap with a washer to keep it from coming off and then you wont lose your spring top collar if the suspension comes up, very simple and cheap.
Sno_Racer_Xtreme
good thinking, thanks mr viper.
