SNOWRULES
Picked up a set of srx powerinc pipes for cheap 150 US. figured i'd try them out see how they work. the guy i bought them from told me they used the stock header pipes. well after i got them home turns out they don't. so my question is does anybody have any? or know where i can get some? or have a picture of one so i can maybe make some up. i figure if i pick up a set of stock srx header pipes even i can probably cut them down and and make them work with some welding.
SNOWRULES
anybody?
maxdlx
VIP Lifetime Member
get a hold of Matt at cb performance he has those pipes, and maybe he can help you out. Maxdlx
pro116
Lifetime VIP Member
Dave at power inc might have some left over get a hold of Richierich him and Dave talkm quite offen.
SNOWRULES
thanks for the help guys i figured it wouldn't be that hard to make some but would be nice to get the original ones.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
If it is the same bolt up to the engine as my pipes are, they are just short manifolds that stick out about an inch. If Richierich cannot get in contact with Dave, I can send you pictures and diagrams of the part that you need to make up or we may beable to make you up the part.
SNOWRULES
thanks 2000 i figured you jump in soon i know you were running these pipes. yes they are the same bolt right up to the engine style. when i took my stock manifolds off the pipes almost touched the exhaust flange when they sat in the right place. like you say only needs to be like an inch or inch and a half long. i will for sure get some pics and info from you to make them if i can't get some. thanks for offering to help really appreciate it.
