Concept Carbon
Ok so sence its warming up and my summer of riding i meen winter sucked, I was thinking of setting up, to do drags at my local drag strip for fun. Would like to run the anything class its like $20 for a whole day. Ive only seen a handfull of sleds ever there.
What is the cheapest minimum starter setup for this?????
Can i just get some skis with wheels, and a flat track and do some jetting.
what else is needed???
Also has anyone made there own skis, if so what did you use for wheels.
pro116
Lifetime VIP Member
ski's and track is all you need.You should put a cool down system on with some quick dsconnects to cool the engine after the run.
Concept Carbon
pro116 said:ski's and track is all you need.You should put a cool down system on with some quick dsconnects to cool the engine after the run.
cool for the cool down system you meen have a like some AN(aircraft Navy) fittings that disconect and hook them up to like a tank in the back of the truck to run cool fluid threw while the sleds running?????
Maim
Super Moderator
bethevipers set up was on here in a post. from what i remeber all it was was a k-car rad with fan and batt with an fittings basically.
