vmax 700 xtc suspension
98venture
hey guys i need to know if i can put a bigger rear shock in on my 98 vmax xtc 700. i usually always ride double and i want to know if there is anything i can do to fix the ride. please let me know. thanks!!
Ya you can get a heavier spring for the rear spring.
There are 3 available for it:
68 8CX-47489-00-00 SPRING1 (K=3.0-5.0) UR AP VX700 XTCPB/XTCDB 1
68 8CX-47489-10-00 SPRING1 (K=3.3-5.3) UR AP XTCPB/XTCDB 1
68 8DH-47489-00-00 SPRING1 (K=3.5-5.5) UR APXTCB 1
I don't know which is heavier but a good dealer should be able to order the right one for you. You can check out the parts catalog for yourself at http://www.yamaha-motor.com/sport/parts/home.aspx and take a look around your entire sled in blowup form.
Your shock is fine you just need eather a stiffer rate spring or move
your fra to C(hard) all the way down.
