MICHAELSF150
I put new boyesen dual stage reeds in my sled. The sled works awsome on bottom end and mid range, big difference in throttle response, when it gets to top end it will only rev to about 7300-7400 rpm it usually revs to 8000 when i have it pined. it seems to be slower too.
MICHAELSF150
do i have to do some jetting?
i put in the rad valves and there great . you may be rich , ck the plugs
MICHAELSF150
how do i know if i am rich? the sled is a 1998 600 vmax sx twin
MICHAELSF150
I changed my main jet size from stock 151.3 to 150. seems to be a little better. My sled goes to about 8100 rpm and then drops back to about 7100 rpm when i have it wide open . Is this normal or should it stay at 8100 rpm ?
yamaholic22
no that is not normal. Did it do this before you put the reeds in? Sounds more like a clutching issue to me. Also could be dirty carbs. When was the last time they were cleaned? How much carbon is on the plugs (what color are they, or post pictures if possible)
MICHAELSF150
yes the sled did this before i put the reeds in. It has done this as long as i can remember
MICHAELSF150
I checked the tech pages and compared my plugs with the ones on there, they look perfect. I still dont know why the sled will go to 8100 rpm and drop back to 7100 when throttle is wide open.
M-Max
sounds like clutching.
MICHAELSF150
what can i do to see if it is clutching?
Sounds like you can't pull the wieght in the clutch at top end. You'll need to list the current setup and then the guys here can point you in a direction or eliminate clutching as a problem.
Weights, rivets and which hole they are in, primary spring, secondary spring, helix, spring wrap.
MICHAELSF150
the clutch setup is stock in the sled. it is a 1998 600 twin the only mods are boyesen reeds , reed spacers and replaced stock main jet 151.3 with 150. thanks for all the help guys
