MtnMax600
I have a friend with a 98 venture that i can get heat exchangers from to replace my leaking LH and RH heat exchangers. Are they the same? Will they work/fit on a 03 mtn viper?
i know the pipes are smaller than the viper ones. they would work with a tunnel cooler in my opinion.
gild
exc
Have a good set off my SXr 01 $100 shipped
Leaking
Why are they leaking? Anyway, Viper and SRX both have 3/4" tubes and everything else has 1/2". The smaller tubes probably would work but if I were you I wouldn't want to restrict the flow and I'd look for the 3/4's
Madmatt
Madmatt
X2...i would find and use the right ones..Madmatt said:Why are they leaking? Anyway, Viper and SRX both have 3/4" tubes and everything else has 1/2". The smaller tubes probably would work but if I were you I wouldn't want to restrict the flow and I'd look for the 3/4's
Madmatt
MtnMax600
Cool, thanks guys. I dont need to restrict flow so ill pass on them.
Madmatt-thats a good question. I wish i knew why they are leaking. I'm not even positive where they are leaking from. They both seem to be doing it where the rear skid brackets go down past the exchangers. But there's no any damage at these spots.
Test them
If I were you I'd test them with some air pressure. I dont know why they would be leaking there.....never heard of such a thing. Why dont you block off one end and rig up a fitting for the other.....put some air pressure on them and thry to see what's up. I've seen them leak around the fittings and if they have been damaged but never in that spot for no aparent reason.
Madmatt
Madmatt
