Viper Treats
Anybody know what the ski camber should be on the C&A's? Sled pulls left, I checked alignment its good, I think the ski is cambered out (out on top) on the left and pulls left when I initiate a right turn. Thanks.
richierich
there isnt any camber on ski.if your alignment is straight check your spindle
Viper Treats
On the doo, there is an adjustment for ski camber, looks like it may be off level. So I should just level it up?
richierich
thats what i would try.so the ski sits flat on ground.
gild
camber
camber is -5 to =5 OEM specs
gild
sorry
-0.5 to +0.5 degrees OEM
yamaholic22
Viper Treats said:Anybody know what the ski camber should be on the C&A's? Sled pulls left, I checked alignment its good, I think the ski is cambered out (out on top) on the left and pulls left when I initiate a right turn. Thanks.
Yea my 97 SX 700 was like that too, and did have a little bit of a pull. I adjusted it so it sat level and then it was good. The adjustment is on the bulkhead side of the radius rods. The radius rods can sometimes be difficult to get back into the bulkhead, but be patient and they will go. Good luck!
