nothinbutansrx
Could someone please tell me what the correct part number stamped on an 01 srx cylinder should be? 8DN?? Thank you.
Turk
TY TECH ADVISER
- May 2, 2003
8dn-01 The 00-02 have the same porting so they should also work.
nothinbutansrx
Thank you. Will an 8dn10 work ? and did they ever make an 8dn20? I checks the part#s in the online cat they listed 98 as 00 99 as 01 and 00-02 as 10. I was curious because the transfers on the bottom of the cylinder don't match the transfers on the crankcase or gasket.
