SRX Rear Suspension Swap
DHSRX
Sudbury, Ontario, Canada
I am looking to replace the rear suspension on my 2001 SRX 700 with the rear suspension from an 2003 RX1. Will this directly bolt on or is there additional work required to make this work?
Thanks,
DHSRX
A member on here (03viperguy) has installed a mono shock skid under his Viper and is going to make a tech artical out of it soon. Check it out here . I am also looking at installing a mono shock skid under my 03 Viper before next year. I called Bender Racing last week and talked about this swap with them and they informed me that they are making a mono shock skid set up for the Viper that will bolt in, cost is around $1300. Has a better shock and 42 selectable positions, not 8 like the stock mono shock skid. -Ed
the 03 RX1 in not a mono shock it is the pro action set up.
It is long travel. You can make your SRX long travel without replacing the skid. You need the rear shocks limiters and transfer rods. Would probably cost about $150.oo with used parts.
