Twist
EricMichael
Presque Isle, ME
Just wondering if anyone knows what twist I should run my helix at..i have a 51/43 green secondary spring. Primary gwg with 8dn-20's(3.6 inner,4.5 outter). They both seem to do the same at 60/70 but i'm not sure if the 60 is hurting me any. I also have it geared up to a 23 top tooth..thanks guys
if it doesn't bog out of the hole run it at 60*. The lower spring twist you can run without slipping the belt or overshifting out of the hole the more efficient the setup!
