Clutch Weights??
2003VIPERER
MARQUETTE MICHIGAN
I WIEIGHED EACH WEIGHT AND 2 OF THEM ARE 56.8 AND ONE IS 56.4. WOULD THIS CREATE A BIG PROBLEM? EVEN WHEN I ADDED 4 GR TO TIP AND 4 GR HEEL. THE ONE ODD ONE WAS STILL .4 L :letitsnow OWER?
That little bit of a difference wont hurt anything, but if you want them to be all the same you could add a touch of weld to the bottom of that weight to make them all the same.
