Belt Squeel
braindead1684
Near Flint Michigan
I have a slight belt squeel on my 96 600xt (vmax) The weird part is it does not do it when its cold, it needs to be fully warmed up and only does it when the sled idles all the way down, and when you get off the sled or let the suspension rebound a little, when you sit on it just right it will go away or get quiter. I did have a cracked engine mount but that has been repaired and the rest look fine, the engine doesn't seem to be flexing at all and was wondering what would be causing this.
