Wow.. I thought when you triple piped, you'd bump up to like 8900-9100... so I hear. Is that other pipes, or end dumps?? Those rpm are lower than stock... how much extra power do they make? Good pipes?Turk said:power inc centre dumps
Pipes need to run at 7900-8150 rpm & absolutely no higher.
So much? Barely 8000 rpm is extremely low, IMO... I was surprised myself.BBlueSRX said:Why do the PI's make their power at so much RPM's? SLP's max out at 8800?
Turk said:Can u get good quality fuel 100% of the time?
Turk said:You will gain a realistic 18-20 hp from pipes. Thinner head gasket is recommended but u gotta run good fuel; u were told 3 times! Stock reeds are fine.What Bender spring? They made 27 of em & they all make your sled run differently. Sounds like u should not do the pipes & keep it stock!
