exciter 2 skid into phazer swap ?
motofishsled
deerpark new york
I would like to install a 92 exciter rear suspension into my 89 phazer . I do not have the exciter tunnel to make measurements from . Has anyone made this swap ? The phazer is a 116" track , the exciter is a 121" track . Does it matter that phazer has 8 tooth driver , exciter has 9 tooth driver ? If someone has old tunnel around and could make template that would be great .thank you .
well i am running an Exciter with 7 tooth drives and i don't have much for top end BUT boy is it quik. I would stay with the 8 tooth and just swap out the skid. I might be going up to ride this or next weekend, I can get the info you want and get it out to you. OH and the only reason I am running the 7 tooth is I have a 136x2.25x15 track.
