Yamanewf
Anyone do any clutch work on a npv 600 with a 136? Would I be right in saying that heavier machine would take more weight in the primary or is it the inverse?
xt700
- Jan 27, 2006
the added weight wont be an issue drag might be, i stretched my 700 and when i did i dropped a tooth off the top(sleds are geared higher than they need to stock) unless your doing radar runs. top end is the same 175 on dream meter, only thing is it hooks up better and gets there faster. if your engine gets loaded up and rpms drop from the swap go to lighter rivets in your weights to bring the revs back up.
Pat
Pat
