Sam88
Another forum member and I are planning on building a drag sled out of a 94 Vmax twin. Its a Hauck 700 Big Bore.
Whats the most compression that anyone has run here on pump gas (93 octane) without detonation? I believe factory is 130psi I was thinking 170 is the MOST.
What compression is any of the 2 stroke guys here running?
One problem is, you could run 170 but the timing isn't able to be changed manually........ I think...
