Camoplast Ice Ripper! How are they?
jaydaniels
Amherst NS
Has anyone tried one of these tracks? Its a 1" 15x121. I found a wicked deal on one so I picked it up. Just wondering how its going to work on my SRX.
I heard they are working out real well. I know a guy who is friends with some of the top dogs at Camoplast and he said they are real happy with them.
its a ripsaw with mini studs.....the ripsaw is amazing on the srx, but you'll have to remove the cooler protectors in front, or go down to an 8-tooth driver in order to avoid rubbing
If it is a 121 X 1" then technically, its an ice-claw (hacksaw)
Onlyblue has one on his attack and on his wife's vector he loves them and he said there better for traction then a regular ripsaw because the lugs are connected so it makes them better for offtrail riding.
A friend of mine has about 3500 miles on a ice ripper on his SXR with 9 tooth drivers and no protectors - he has had absolutely no contact made between the front cooler and the studs or any other area for that matter. Based on that observation I will make the following statement: You can run a ice ripper on a Yamaha SXR 700 and on the models with similar chassis and clearances between the drivers and the coolers/heat exchangers.
I'm putting one on the Viper S next year - without re gearing, adding protectors, or going to 8 tooth drivers.
xs
Is it the Ice Claw that is the 136" version? That's the one I want and then run an additional 96 real trail studs up the middle. I heard one guy doing this and he couldn't imagine being able to get better all around hook up.
My brother has one in his ´00 SRX 700. Great track! Better traction than my 136 inch ripsaw...
Ike
Ice claw is a 1" lug with 240 mini lug studs. The Ice ripper is the rip saw with the same lug studs.
