I just installed a set of Heavy Hitter clutch weights and Maxx Perf purple primary spring, formerly ran Heelclickers. Anyhow, when I installed these weights and began pulling the sled over to start, I noticed a "pinging" sound coming from the primary. Upon further inspection, I noticed that the rollers are not in direct contact with the heel of the weight, you have to move the weight with your finger a bit to make it come in contact with all 3 rollers. Is this a problem regarding the shim I have between the primary cover and primary spring or is it something else? Thanks.
