I have a 02 Viper and the shift out is 9000 RPM. It has a heelclicker clutch kit, but I'm not sure what I have for weights ect.... Bought it winter of 06. It pulls good on bottom, midrange is ok and top end is 9000. Somethings is wrong. I do alot of river riding so if anybodys go suggestions please help. Any suggestions on suspension setting would also be nice. I'm 6' 260lbs.
Bender Pipes
VFORCE3 Reeds
artic_cat_dan@hotmail.com
Bender Pipes
VFORCE3 Reeds
redsnake3
needs to be at 8800rpm for the bender pipes. the heel clickers have there own weight which is adjustable by adding bolts, washers and set screws to threaded areas in the weight.
to the site.
maxwell
To start with, you need to find out what weight you have in currently. Sounds to me like you need to add weight to the middle or tip. if the middle is empty, add a bit of weight and then add weight to the tip.
Welcome!!!!!!
^^ what these guy's said,,and i would think you need more tip weight to
bring your R's down..
