Oldwrench
- Dec 4, 2003
Hi,
I have an 03 SX Viper ER.
In all the illustrations I've seen the front arm bushings look like a sleeve with a collar. On mine all there is a fiber washer and a metal backer. Before I put it back together I just want to know if the illustration is misleading or I'm missing something.
Oldwrench said:Hi,
You could have an after market arm or a bushing kit...need to post pics for us to help out...look at this
http://parts.yamaha-motor.com/partimage.gifx?d=49989,2,0
good luck
SRX7
are you talking about the front susp or skid?
Yup little mo info..
I have seen them wear out until they separate leaving the sleeve in the trailing arm and what looks like a washer on the outside. The metal washer is supposed to be there.
SRX7
What ding said. When my skid was out I notice my left side bushing had separated from its main body. I just put it back on and installed the skid. The main part of the bushing is somewhere in the w arm. I just wanted the plastice ring part in its place to keep the same clearence along with the metal washer.
bolin22
oh those little buggers.....lol
Oldwrench
- Dec 4, 2003
Thanks for all the replys.
The bushing I was referring to is the one for the front torque arm of the rear suspension.
I cannot open the illustrations for Port Yamaha so I went to hlsm.
They list it as #6 Bush, Solid.
Whatever is left of mine is anything but solid.
What remains reminds me of the fiber washers that were used on oil pan plugs.
Anyway, I'm going to order what they list as solid bushings and washer plates.
Thanks again
Steve
Thanks again
Steve
Yes, those bushings wear out completely leaving strange looking pieces behind. I have a bunch lying on the floor right now from 2 skids I rebuilt recently. Time to clean up the shop for sure.
Oldwrench
- Dec 4, 2003
Thanks again,Ding said:Yes, those bushings wear out completely leaving strange looking pieces behind. I have a bunch lying on the floor right now from 2 skids I rebuilt recently. Time to clean up the shop for sure.
I'll order more than one replacement set.
