Thats Cool Do U Know If Srx Are Good In Water ??? Did U Block Any Vent In The Front Of The Sled For The Water... Do U Run Stock Track
change_up
I wanna watch!!! How do I enable Java Script? It says I either need the newest version of Macromedia's Flash Player or I have disabled java script... I tried downloading the flash player and I already have it.
modsrx said:Thats Cool Do U Know If Srx Are Good In Water ??? Did U Block Any Vent In The Front Of The Sled For The Water... Do U Run Stock Track
srx+water= srx in bottom of lake.
I've seen SRXs run water, they are Ok, but not great IMO. Some guys sunk one in that exact spot last weekend. You should tape off the two lower vents on the belly pan. I've also heard you need to silicon a couple holes in the tunnel at the top of the front exchanger. SNOWRULES could tell you where more specifically. I ran my Viper without any tape.
All I can say is if you are going to try it, start short and keep it to the bar!
How about SRX = Sucks River Xing...LOL
I have ran srx's along ways across water many times just silicone the shock towers so water dosen't get on the clutch and they cross just fine.
yamaholic22
pro116 said:I have ran srx's along ways across water many times just silicone the shock towers so water dosen't get on the clutch and they cross just fine.
I completely agree! My srx and sxr's were all awesome on water once you seal up the vents. C&A's really help a lot too. And i definately dont put it to the bar, i run more around half throttle.
