Torque values 01 sxr 700 chaincase
bco2jco
central ny
I just swapped out my chaincase and was wondering if anyone can tell me the torque rating for the 14mm bolt that holds the larger bottom gear on? I am concerned about getting it right. The washer under this bolt cracked leaving half under the bolt and the rest to spin around in the case leaving a few large chunks but mostly disintigrating. A cracked chaincase resulted. Has anyone seen this before or know what caused it?
Also the torque value for the bolt that holds the secondary on? Thanks! My sled is a 2001 sx700.
these specs are from 1997 700sx and should be the same....
48Nm/35ftlbs for bolt that holds lower gear
64nm/46ftlbs for secondary bolt
