Need Help
portsevernsledder
Brampton, Ontario, Canada
I had to replace my cdi on my 98 venture 600 twin :o| it runs now but has a bad bogging problem, I will only go 60 to 80 km now and the diagnostic light no longer blinks when starting. Also my fuel gauge is also not working and I have a backup beeper that beeps when in reverse that no longer works. Has anyone out there have any idea what has gone wrong and what I should do?
Thanks. :o| :o| :o|
If there is not a battery hooked up it may cause the problem.
Does the electric starter work?
If nothing else was done beside changing the CDI, there may be a problem with it or the connections.
Was it a new box from Yamaha?
Did you do some other things while diagnosing the problem?
Does the battery turn the starter?
