Can you run a studded 1.250 ripsaw on a sx with 9 toth drivers?
neal
i dont think so. i think 1" is the largest you can run on a stock sx. i am not 100% sure though.
I Believe You'll have to run 8 tooth drivers in order to clear the front heat exchanger. but it can be done. I think it would be worth the effort.
NO. if you leave the tunnel protectors in they will wear grooves in the track, but that is the only way to do it w/ 9 tooth drivers. YES it is possible, but are you willing to wear a new track? It will clear the heat exchanger but not the protectors
yamaholic22
Put in 8 tooth drivers with the studded 1.25" track and correct the gear ratio and you will have no issues with clearance like you will if you leave the 9 tooth's in there.
