This is how my drivebelt looked after a several km hard run on the river.
Clutch set up: Hc with approx 4,6 gram in heel, and 3.3 gram in tip.
47/42 helix and green spring at 70 degrees.
Felt the clutch, inner sheave wasn't very hot, I could hold my hand to it several seconds, while the outer, moving sheave was "stone cold".
I don't understand what could have happened here? It slipped maybe? Or maybe just a bad belt?
Clutches should be aligned.
As you can see, the top layer peeled off.
blue missile
was it a yammi belt
Old belt will do that...
Thanks.
More possibillities?
jr_amsoil
probably just worn out
Thanks for the replies, keep them coming
98srx6
Probably just old and worn out. I have seen that happen with a clutch that was setup with too much secondary twist...however, the belt was old and worn out on that sled too...
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
How so? Does it eat away at the belt because the secondary is wrapped too tight, not allowing the clutches to shift out(upshift)?
